数据集里面使用if判断报错
${if (substr('$date1',5,2) == "01","select * from B","select * from A")} ,这个IF判断是哪里有问题吗
FineReport uWu 发布于 2022-4-6 10:49
发布于2022-4-6 10:50(编辑于 2022-4-6 10:53)
${if (mid(date1,5,2) == "01","select * from B","select * from A")}
发布于2022-4-6 11:25(编辑于 2022-4-6 11:29)
${if(mid(date1,5,2) = "01","select * from B","select * from A")}
要用mid函数了。你这样写的时候,要用帆软内置的函数mid同时最外面加了${}后。里面的不用加$了。。
  • 573浏览人数
  • 最后回答于:2022-4-6 11:29
