问:哪位大佬能把漏斗图放在坐标轴里吗?
FineReport 数字化转型的学习者 发布于 2022-9-19 21:10 (编辑于 2022-9-19 22:53)
陌落丿Lv3初级互助
发布于2022-9-20 09:53(编辑于 2022-9-20 09:57)
帆软没有现成的图形可以支持,尝试一下用面积图实现波动,然后在特效-条件属性里将波谷数据、x轴进行隐藏,看是否能满足需求吧
select * from (
select 1 as cnt,0 as cnt1,1 as cnt2
union all
select 2 as cnt,0.85 as cnt1,1 as cnt2
union all
select 3 as cnt,0 as cnt1,1 as cnt2
union all
select 3 as cnt,0 as cnt1,2 as cnt2
union all
select 4 as cnt,0.67 as cnt1,2 as cnt2
union all
select 5 as cnt,0 as cnt1,2 as cnt2
union all
select 5 as cnt,0 as cnt1,3 as cnt2
union all
select 6 as cnt,0.72 as cnt1,3 as cnt2
union all
select 7 as cnt,0 as cnt1,3 as cnt2
) n order by n.cnt
weibwLv7高级互助
发布于2022-9-19 21:11(编辑于 2022-9-19 21:20)
组合图里没有漏斗图选项,所以应该是实现不了的
  • 307浏览人数
  • 最后回答于:2022-9-20 09:57
