select ${if(车间 == '制卷车间',"prod_line_name,","prod_line_code as prod_line_name,")} sum(output_qty) as output_qty1 , max(plan_qty)*24 as plan_qty1, case when max(plan_qty) = 0 then 1 else toFloat32(sum(output_qty)) / toFloat32((max(plan_qty)*24)) end as completion_rate from (select prod_category_name2, department_name , workshop_name, data_date, case when operation_name = '负极分切' then '负极二次分条' when operation_name = '正极分切' then '正极二次分条' when operation_name = '侧缝焊外观判定及关键尺寸测量' then '侧缝焊判定测量' else operation_name end as operation_name, base_code , factory_stage , product_model , toFloat32(case when operation_name in ('正极涂布','负极涂布','正极一次分条','正极辊压','正极二次分条','负极一次分条','负极辊压','负极二次分条','切叠','热压','极耳预焊','正极预分','正极分切','负极预分','负极分切') then toFloat32(output_qty)*0.5 when operation_name in ('正极合浆','负极合浆') then toFloat32(output_qty) else toFloat32(output_qty) end) as output_qty, plan_qty, prod_line_code, prod_line_name, work_last_oper_flag, prod_last_oper_flag from zh_dws.dws_mfg_equip_production_h where 1=1 and prod_category_name2 = '电芯' AND workshop_name = '${车间}' AND factory_stage = '${工厂}' ${if(车间 == '制卷车间',"AND prod_last_oper_flag = 'Y'","AND work_last_oper_flag = 'Y'")} ${if(len(日期) == 0,"and toString(data_date) = formatDateTime(subtractHours(now(),9),'%Y-%m-%d')","and toString(data_date) = ('" + 日期 + "')")} group by data_date, product_model, prod_category_name2, base_code, factory_stage , workshop_name , department_name , operation_name , prod_line_code, prod_line_name, work_last_oper_flag, prod_last_oper_flag ) group by prod_line_name,prod_line_code order by prod_line_code |
