最佳回答 |
CD20160914Lv8专家互助发布于2023-5-19 11:11
${if(lv="0","",if(len(dept2)=0,"and dept_code='"+dept+"'","and dept_code='"+dept2+"'"))}
最佳回答 |
用户k6280494Lv6专家互助发布于2023-5-19 11:11
${if(LV=0,"",if(len(DEPT2)=0,"and DEPT_code='"+DEPT+"'","and DEPT_code='"+DEPT2+"'"))}
最佳回答 |
Z4u3z1Lv6专家互助发布于2023-5-19 11:12
${IF(LV==0,"",IF(LEN(DEPT2)==0," AND DEPT_CODE='"+DEPT+"'"," AND DEPT_CODE='"+DEPT2+"'"))}
最佳回答 |
luojian0323Lv7资深互助发布于2023-5-19 11:13
${if(LV="0","",if(len(LV)=0," and DEPT_CODE='"+DEPT+"'"," and DEPT_CODE='"+DEPT2+"'"))}
最佳回答 |
年年plusLv5中级互助发布于2023-5-19 11:14
${if(lv='0',"",if(len(dept2)=0," and DEPT_CODE='"+dept+"'","and DEPT_CODE='"+dept2+"'"))}
最佳回答 |
神威Lv3见习互助发布于2023-5-19 11:19
${IF(LV=0,"",IF(LEN(DEPT2)=0,"AND DEPT_code='"+DEPT+"'","AND DEPT_code='"+DEPT2+"'"))}
