java.lang.RuntimeException: java.util.concurrent.ExecutionException: com.finebi.exception.DSInterruptedException: java.lang.RuntimeException: java.util.concurrent.ExecutionException: com.finebi.spider.sparksql.exception.SpiderWrapSparkException: com.finebi.exception.DSInterruptedException: java.lang.RuntimeException: java.util.concurrent.ExecutionException: org.apache.spark.SparkException: Job aborted due to stage failure: Task 0 in stage 969378.0 failed 1 times, most recent failure: Lost task 0.0 in stage 969378.0 (TID 981867) (WIN-CA0PST2MGP0 executor driver): org.apache.spark.SparkException: Failed to execute user defined function(functions$$$Lambda$9680/1758078813: (int, string) => bigint) \n at org.apache.spark.sql.catalyst.expressions.GeneratedClass$GeneratedIteratorForCodegenStage16.processNext(Unknown Source) \n at org.apache.spark.sql.execution.BufferedRowIterator.hasNext(BufferedRowIterator.java:43) \n at org.apache.spark.sql.execution.WholeStageCodegenExec$$anon$1.hasNext(WholeStageCodegenExec.scala:755) \n at scala.collection.Iterator$$anon$10.hasNext(Iterator.scala:460) \n at scala.collection.Iterator$$anon$10.hasNext(Iterator.scala:460) \n at org.apache.spark.util.random.SamplingUtils$.reservoirSampleAndCount(SamplingUtils.scala:41) \n at org.apache.spark.RangePartitioner$.$anonfun$sketch$1(Partitioner.scala:306) \n at org.apache.spark.RangePartitioner$.$anonfun$sketch$1$adapted(Partitioner.scala:304) \n at org.apache.spark.rdd.RDD.$anonfun$mapPartitionsWithIndex$2(RDD.scala:915) \n at org.apache.spark.rdd.RDD.$anonfun$mapPartitionsWithIndex$2$adapted(RDD.scala:915) \n at org.apache.spark.rdd.MapPartitionsRDD.compute(MapPartitionsRDD.scala:52) \n at org.apache.spark.rdd.RDD.computeOrReadCheckpoint(RDD.scala:373) \n at org.apache.spark.rdd.RDD.iterator(RDD.scala:337) \n at org.apache.spark.scheduler.ResultTask.runTask(ResultTask.scala:90) \n at org.apache.spark.scheduler.Task.run(Task.scala:131) \n at org.apache.spark.executor.Executor$TaskRunner.$anonfun$run$3(Executor.scala:497) \n at org.apache.spark.util.Utils$.tryWithSafeFinally(Utils.scala:1439) \n at org.apache.spark.executor.Executor$TaskRunner.run(Executor.scala:500) \n at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) \n at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) \n at java.lang.Thread.run(Thread.java:748) \nCaused by: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.Long \n ... 21 more \n\nDriver stacktrace:) |
