declare @strString VARCHAR(max) = '' -- 循环赋值内容的字符串 declare @index int = 1 --起始下标 declare @tableCount int = 0 --主表行数
set @tableCount = (select count(1) from #TmpAll)
WHILE(@index <= @tableCount) begin select @MaterialCode = a.MaterialID,@SizeName = sz.SizeName,@StockID = InStockID, @CheckDate = InCheckDate from #TmpAll a inner join SD_Mat_Size sz on a.SizeID=sz.SizeID where id = @index
-- 7天
set @strString = '' select @seveDay = sum(qty) from #tableA_2 where MaterialCode = '' + @MaterialCode +'' and SizeName = '' + @SizeName +'' and StockID = '' + @StockID +'' and CheckDate BETWEEN CONVERT(varchar(100), @CheckDate, 20) and DATEADD(dd,7,CONVERT(varchar(100), @CheckDate, 20))
-- 14天 select @fourThen = sum(qty) from #tableA_2 where MaterialCode = '' + @MaterialCode +'' and SizeName = '' + @SizeName +'' and StockID = '' + @StockID +'' and CheckDate BETWEEN CONVERT(varchar(100), @CheckDate, 20) and DATEADD(dd,14,CONVERT(varchar(100), @CheckDate, 20)) --21天 select @twentyOne = sum(qty) from #tableA_2 where MaterialCode = '' + @MaterialCode +'' and SizeName = '' + @SizeName +'' and StockID = '' + @StockID +'' and CheckDate BETWEEN CONVERT(varchar(100), @CheckDate, 20) and DATEADD(dd,21,CONVERT(varchar(100), @CheckDate, 20)) --28天 select @twentyEight = sum(qty) from #tableA_2 where MaterialCode = '' + @MaterialCode +'' and SizeName = '' + @SizeName +'' and StockID = '' + @StockID +'' and CheckDate BETWEEN CONVERT(varchar(100), @CheckDate, 20) and DATEADD(dd,28,CONVERT(varchar(100), @CheckDate, 20))
set @strString = @strString + ' update #TmpAll set ' if @seveDay > 0 begin set @strString = @strString + ' count1 = ' + CONVERT(varchar(100), @seveDay, 20) +',' end if @fourThen > 0 begin set @strString = @strString + ' count2 = ' + CONVERT(varchar(100), @fourThen, 20)+',' end if @twentyOne > 0 begin set @strString = @strString + ' count3 = ' + CONVERT(varchar(100), @twentyOne, 20)+',' end set @strString = @strString + ' count4 = ' + CONVERT(varchar(100), @twentyEight, 20)
set @strString = @strString + ' where id = ' + CONVERT(varchar(100), @index, 20) + ' ;'
set @index = @index + 1 end print @strString -- 打印为空 |
最佳回答 |
