报错信息为: inserted value too large for column: search table error: [4013] value conversion failed;exception 70004013: cannot convert "100" to the type VARCHAR(2) for column PM ,Exception in executor plan337098564@hanaphn01 原语句: SELECT A.*,B.DTXS,A.TB-1 AS TBZF,A.HB-1 AS HBZF,TB.TBSJXSJS,HB.HBSJXSJS,DY.SJXSJS,QN.QNSJXSJE ,JN.JNSJXSJE FROM ( SELECT * FROM "_SYS_BIC"."CB.AL.YW/ZAL_BMYXSJDB" (PLACEHOLDER."$$CALMONTH$$"=>'202308', PLACEHOLDER."$$CALDAY$$"=>'20230813' ) WHERE 1=1 --AND ZICZS0000 IN (${GET_ZICZS0000}) ) A LEFT JOIN (SELECT ZICZS0000,SUM(SJXSJE) AS DTXS FROM( SELECT A.ZICZS0000,A.CALMONTH AS YF,A.ZIFXAV010 AS SJXSJE FROM "_SYS_BIC"."CB.BL.YW/ZBL_ZDDSD001" A INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICZA0000" B ON A.ZICZA0000=B.ZICZA0000 INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICXA0001" C ON A.ZICXA0001=C.ZICXA0001 WHERE (ZICXA0004='21' OR ZICXA0004='22' OR ZICXA0004='20' OR ZICXA0004='23') AND B.ZICZB0075<>'N' AND C.ZICXA0005='Y' AND A.CALDAY='20230813' AND A.ZICZS0008<>'8009194' --屏蔽大客户 ) GROUP BY ZICZS0000 ) B ON A.ZICZS0000=B.ZICZS0000 LEFT JOIN ( SELECT ZICZS0000,YF AS TBYF,SUM(SJXSJS) AS TBSJXSJS FROM( SELECT A.ZICZS0000,A.CALMONTH AS YF,A.ZIFXAJ022 AS SJXSJS FROM "_SYS_BIC"."CB.BL.YW/ZBL_ZDDSD001" A INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICZA0000" B ON A.ZICZA0000=B.ZICZA0000 INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICXA0001" C ON A.ZICXA0001=C.ZICXA0001 WHERE (ZICXA0004='21' OR ZICXA0004='22' OR ZICXA0004='20' OR ZICXA0004='23') AND B.ZICZB0075<>'N' AND C.ZICXA0005='Y' AND A.CALMONTH='20220813' AND A.ZICZS0008<>'8009194' --屏蔽大客户 ) GROUP BY ZICZS0000,YF
) TB ON A.ZICZS0000=TB.ZICZS0000 LEFT JOIN ( SELECT ZICZS0000,YF AS TBYF,SUM(SJXSJS) AS HBSJXSJS FROM( SELECT A.ZICZS0000,A.CALMONTH AS YF,A.ZIFXAJ022 AS SJXSJS FROM "_SYS_BIC"."CB.BL.YW/ZBL_ZDDSD001" A INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICZA0000" B ON A.ZICZA0000=B.ZICZA0000 INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICXA0001" C ON A.ZICXA0001=C.ZICXA0001 WHERE (ZICXA0004='21' OR ZICXA0004='22' OR ZICXA0004='20' OR ZICXA0004='23') AND B.ZICZB0075<>'N' AND C.ZICXA0005='Y' AND A.CALMONTH='20230713' AND A.ZICZS0008<>'8009194' --屏蔽大客户 )GROUP BY ZICZS0000,YF
) HB ON A.ZICZS0000=HB.ZICZS0000
LEFT JOIN ( SELECT ZICZS0000,YF AS TBYF,SUM(SJXSJS) AS SJXSJS FROM( SELECT A.ZICZS0000,A.CALMONTH AS YF,A.ZIFXAJ022 AS SJXSJS FROM "_SYS_BIC"."CB.BL.YW/ZBL_ZDDSD001" A INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICZA0000" B ON A.ZICZA0000=B.ZICZA0000 INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICXA0001" C ON A.ZICXA0001=C.ZICXA0001 WHERE (ZICXA0004='21' OR ZICXA0004='22' OR ZICXA0004='20' OR ZICXA0004='23') AND B.ZICZB0075<>'N' AND C.ZICXA0005='Y' AND A.CALMONTH='202308' AND A.ZICZS0008<>'8009194' --屏蔽大客户 )GROUP BY ZICZS0000,YF
) DY ON A.ZICZS0000=DY.ZICZS0000 LEFT JOIN ( SELECT ZICZS0000,SUM(SJXSJE) AS QNSJXSJE FROM( SELECT A.ZICZS0000,A.CALMONTH AS YF,A.ZIFXAV010 AS SJXSJE FROM "_SYS_BIC"."CB.BL.YW/ZBL_ZDDSD001" A INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICZA0000" B ON A.ZICZA0000=B.ZICZA0000 INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICXA0001" C ON A.ZICXA0001=C.ZICXA0001 WHERE (ZICXA0004='21' OR ZICXA0004='22' OR ZICXA0004='20' OR ZICXA0004='23') AND B.ZICZB0075<>'N' AND C.ZICXA0005='Y' AND A.CALYEAR='2022' AND A.CALDAY<='20220813' AND A.ZICZS0008<>'8009194' )GROUP BY ZICZS0000
) QN ON A.ZICZS0000=QN.ZICZS0000
LEFT JOIN ( SELECT ZICZS0000,SUM(SJXSJE) AS JNSJXSJE FROM( SELECT A.ZICZS0000,A.CALMONTH AS YF,A.ZIFXAV010 AS SJXSJE FROM "_SYS_BIC"."CB.BL.YW/ZBL_ZDDSD001" A INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICZA0000" B ON A.ZICZA0000=B.ZICZA0000 INNER JOIN "_SYS_BIC"."CB.BL.MD/MD_ZICXA0001" C ON A.ZICXA0001=C.ZICXA0001 WHERE (ZICXA0004='21' OR ZICXA0004='22' OR ZICXA0004='20' OR ZICXA0004='23') AND B.ZICZB0075<>'N' AND C.ZICXA0005='Y' AND A.CALYEAR='2023' AND A.CALDAY<='20230813' AND A.ZICZS0008<>'8009194' )GROUP BY ZICZS0000 ) JN ON A.ZICZS0000=JN.ZICZS0000 WHERE JN.JNSJXSJE<>0 OR A.ZIFYY0801>0 ORDER BY A.ZICZS0000 |
