使用demo数据库连接报错
当前驱动加载路径:/data/demo_FR/webroot/WEB-INF/lib/mysql-connector-java-5.1.49-bin.jar
检测驱动
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server. at sun.reflect.GeneratedConstructorAccessor818.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at com.mysql.jdbc.Util.handleNewInstance(Util.java:403) at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:990) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:335) at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2187) at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2220) at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2015) at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:768) at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47) at sun.reflect.GeneratedConstructorAccessor341.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at com.mysql.jdbc.Util.handleNewInstance(Util.java:403) at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:385) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:323) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1666) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1732) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2907) Caused by: java.net.ConnectException: 连接超时 (Connection timed out) at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:211) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:299) ... 14 more
FineDataLink yzm158840 发布于 2023-10-17 11:22
悬赏:0 F币 + 添加悬赏
发布于2023-10-17 11:24
检查驱动版本
[平台]MySQL数据连接-https://help.fanruan.com/finereport/doc-view-2560.html
  • 148浏览人数
  • 最后回答于:2023-10-17 11:24
