本月执行第一段sql,其他月执行第二段sql
有参数$edate
值形如2023-11
当前月为2023-11
如果参数为2023-11就执行
select *
from xx
where 1=1
and date = '${edate}'
如果参数为其他就执行
select *
from xx
where 1=1
and aaa
and date ='${edate}'
FineReport Juint 发布于 2023-11-15 16:41
共5回答
发布于2023-11-15 16:44
${if(edate=left(today(),7),
"select *
from xx
where 1=1
and date = '"+edate+"'",
"select *
from xx
where 1=1
and aaa
and date ='"+edate+"'"
发布于2023-11-15 16:43(编辑于 2023-11-15 16:44)
select * from XXX表
where 1=1
${if(edate="2023-11","and date='"+edate+"'","and aaa and date='"+edate+"'")}
快乐星光Lv5中级互助
发布于2023-11-15 16:44
select *
from xx
where 1=1
${if(edate='2023-11',"and aaa","")}
'2023-11'可以用一个参数代替,在参数里面做today公式变形
kalashangLv3高级互助
发布于2023-11-15 16:44
select *
from xx
where 1=1
and date = '${edate}' ${if(FORMAT(TODAY(),"yyyy-MM")=edate,""," and 1<>1")}
union all
select *
from xx
where 1=1
and aaa
and date ='${edate}' ${if(FORMAT(TODAY(),"yyyy-MM")=edate," and 1<>1","")}
touyuan001Lv6中级互助
发布于2023-11-15 16:46
${if(edate="2023-11","and 1=1","and 1=2")}
  • 321浏览人数
  • 最后回答于:2023-11-15 16:46
