帆软if筛选条件怎么写
当输入月份为当月时,
SELECT sum(le.NUM) FROM T_CO_WALKTHROUGHS_SCHEDULING le WHERE REGEXP_LIKE(le.num, '^-?[0-9]+(\.[0-9]+)?$') AND to_char(le.MONTH_ID , 'yyyy-mm') =TO_CHAR(SYSDATE, 'YYYY-MM') AND le.PRODUCTION_DATE >= TRUNC(SYSDATE, 'MM')
AND le.PRODUCTION_DATE <= SYSDATE AND le.LINENAME IN('A01', 'A02')
当输入月份为历史月份时,SELECT sum(le.NUM) FROM T_CO_WALKTHROUGHS_SCHEDULING le WHERE REGEXP_LIKE(le.num, '^-?[0-9]+(\.[0-9]+)?$') AND to_char(le.MONTH_ID , 'yyyy-mm') ='2024-02' AND le.LINENAME IN('A01', 'A02')
这个语句怎么使用一个if实现筛选
FineReport yzm136176 发布于 2024-3-12 11:30
发布于2024-3-12 11:35
cs就是控件名,格式是yyyy-MM格式
${if(cs=format(today(),"yyyy-MM"),"SELECT sum(le.NUMFROM T_CO_WALKTHROUGHS_SCHEDULING le WHERE REGEXP_LIKE(le.num, '^-?[0-9]+(\.[0-9]+)?$'AND to_char(le.MONTH_ID , 'yyyy-mm') =TO_CHAR(SYSDATE'YYYY-MM'AND le.PRODUCTION_DATE >= TRUNC(SYSDATE'MM')","SELECT sum(le.NUM) FROM T_CO_WALKTHROUGHS_SCHEDULING le WHERE REGEXP_LIKE(le.num, '^-?[0-9]+(\.[0-9]+)?$') AND to_char(le.MONTH_ID , 'yyyy-mm') ='"+cs+"' AND le.LINENAME IN('A01', 'A02')")}
CovidLv3高级互助
发布于2024-3-12 11:34(编辑于 2024-3-12 11:37)
AND le.PRODUCTION_DATE <= SYSDATE AND le.LINENAME IN('A01', 'A02') ${if(AND(month(today())==month(参数名),YEAR(today())==YEAR(参数名)),""," AND 1<>1")}
union all
SELECT sum(le.NUM) FROM T_CO_WALKTHROUGHS_SCHEDULING le WHERE REGEXP_LIKE(le.num, '^-?[0-9]+(\.[0-9]+)?$') AND to_char(le.MONTH_ID , 'yyyy-mm') ='2024-02' AND le.LINENAME IN('A01', 'A02') ${if(AND(month(today())==month(参数名),YEAR(today())==YEAR(参数名))," AND 1<>1","")}
也可以换成
${if(AND(month(today())==month(参数名),YEAR(today())==YEAR(参数名)),SQL1,SQ2)}
  • 214浏览人数
  • 最后回答于:2024-3-12 11:37
