SQL错误
SELECT
  PRODUCE_AGING_DESC,--库龄区间
  PRODUCE_AGING_NUM,
  CASE WHEN F.MATERIAL_CLASS_L1_NAME IN( '浆','花') THEN SUM(CVT_INV_NM)/10000 ELSE SUM(CVT_INV_NM)/1000 END AS  CVT_ONHAND --库存量
FROM ADS_EBS_INV_HQTY_DETAIL F
WHERE IF('${ty}'='粉',F.MATERIAL_CLASS_L2_NAME = '粉',F.MATERIAL_CLASS_L1_NAME = '${ty}')
  AND F.INV_CLASS_01_NAME = '成品库'
  AND ( F.OU_ID = 102 OR F.OU_ID = 127 )
  AND F.YM_ID = '${P_S_DATE}'
GROUP BY F.PRODUCE_AGING_DESC, F.PRODUCE_AGING_NUM,F.MATERIAL_CLASS_L1_NAME
ORDER BY F.PRODUCE_AGING_NUM
大佬们可以帮忙看一下这个SQL哪里有问题吗?预览的时候显示缺少括号,但我对的没少呀
FineReport 嘘.. 发布于 2024-8-27 11:07 (编辑于 2024-8-27 11:23)
发布于2024-8-27 11:09(编辑于 2024-8-27 11:31)
SELECT
  PRODUCE_AGING_NUM,
  CASE WHEN F.MATERIAL_CLASS_L1_NAME IN('浆','花') THEN SUM(CVT_INV_NM)/10000 ELSE SUM(CVT_INV_NM)/1000 END AS  CVT_ONHAND --库存量
WHERE ${IF(ty='粉',"F.MATERIAL_CLASS_L2_NAME = '粉'","F.MATERIAL_CLASS_L1_NAME = '"+ty+"'")}
0035705Lv5初级互助
发布于2024-8-27 11:09
where 后面加上  1=1
  • 151浏览人数
  • 最后回答于:2024-8-27 11:31
