如何提交时,实时查询数据库表,然后将查询到的结果在报表填报属性中写入,然后入库
image.pngsql("FRformal", "WITH TaskCounts AS (
    SELECT
        a.User_Id,
            SELECT
                COUNT(b.User_Id)
            FROM PD_Users b
            LEFT JOIN VIEW_Project c ON c.Scorer_Personnel = b.User_Id
            LEFT JOIN VIEW_Project_Process d ON d.Project_Id = c.Project_Id AND d.Project_Node = c.Project_Node
            WHERE b.Position = '询价工程师'
                AND d.Project_Process = '待复核评分'
                AND (d.Project_State = 1 OR d.Project_State = 3)
                AND b.User_Id = a.User_Id
                AND is_mark = '否'
        ) AS task_count
    FROM
        PD_Users a
    WHERE
        a.Position = '询价工程师'
        AND a.Data_State = 1
        AND a.User_Id IN (SELECT person_id FROM PD_Allocation_Region)
MinTaskCount AS (
    SELECT MIN(task_count) AS min_task_count
    FROM TaskCounts
MinTaskUsers AS (
    SELECT User_Id
    FROM TaskCounts
    WHERE task_count = (SELECT min_task_count FROM MinTaskCount)
MinTaskUsersCount AS (
    SELECT COUNT(*) AS min_task_users_count
    FROM MinTaskUsers
RegionFilteredUsers AS (
    SELECT person_id
    WHERE area = '${AD7}'
SELECT User_Id
FROM MinTaskUsers
WHERE
    (SELECT min_task_users_count FROM MinTaskUsersCount) > 1
    AND User_Id IN (SELECT person_id FROM RegionFilteredUsers)
UNION ALL
SELECT User_Id
FROM MinTaskUsers
WHERE
    (SELECT min_task_users_count FROM MinTaskUsersCount) = 1", 1, 1)
这个sql有点复杂,是可以查询出结果的,但是写在报表填报属性的单元格函数中就不行,是格式有问题,还是不支持呢
FineReport ii起风了 发布于 2024-8-28 14:56
发布于2024-8-28 14:58
拼接问题
    SELECT
        a.User_Id,
            SELECT
                COUNT(b.User_Id)
            FROM PD_Users b
                AND is_mark = '否'
        ) AS task_count
    FROM
        PD_Users a
    WHERE
MinTaskCount AS (
    FROM TaskCounts
MinTaskUsers AS (
    SELECT User_Id
    FROM TaskCounts
    FROM MinTaskUsers
    SELECT person_id
    WHERE area = '"+AD7+"'
SELECT User_Id
FROM MinTaskUsers
WHERE
UNION ALL
SELECT User_Id
FROM MinTaskUsers
WHERE
主要是这边原因
shirokoLv6资深互助
发布于2024-8-28 14:59
image.png这个不行,这里实际是字符串,不能用数据集那套,应该改成 sql("xxx","语句前半段....='"+AD7+"' 语句后半段",1,1)
青春只因年少Lv6中级互助
发布于2024-8-28 15:00(编辑于 2024-8-28 15:01)
  • 155浏览人数
  • 最后回答于:2024-8-28 15:01
