在BI中不好处理,直接在sql的数据源中处理,在BI数据源中加上这一列吧,比如在oracel中类似这样
with your_table as(
SELECT 'A11s4t7DE64srtoi' AS your_column
FROM dual )
select LISTAGG(t.uppercase_letter,'') WITHIN GROUP (ORDER BY uppercase_letter) as 拼接列 from (
SELECT REGEXP_SUBSTR(your_column, '[A-Z]', 1, LEVEL) AS uppercase_letter
FROM your_table
CONNECT BY REGEXP_SUBSTR(your_column, '[A-Z]', 1, LEVEL) IS NOT NULL
AND PRIOR your_column = your_column
AND PRIOR SYS_GUID() IS NOT NULL) t
