连不上本地数据库,但是换了其他的报表工具连接成功,这是什么原因呢
FineReport yzmpDJy83600781 发布于 2024-11-29 11:10
共5回答
发布于2024-11-29 11:11
看一下详情情况说明是什么
  • yzmpDJy83600781 yzmpDJy83600781(提问者) 报错信息:当前驱动加载路径:E:\fanruan\FineReport_11.0\webapps\webroot\WEB-INF\lib\mysql-connector-java-5.1.49-bin.jar java.sql.SQLException: Access denied for user 'root'@'172.17.178.64' (using password: YES) com.mysql.jdbc.SQLError.createSQLException(SQLError.java.965) com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java.3933) com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java.3869) com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java.864) com.mysql.jdbc.MysqlIO.proceedHandshakeWithPluggableAuthentication(MysqlIO.java.1707) com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java.1217) com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java.2189) com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java.2220) com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java.2015) com.mysql.jdbc.ConnectionImpl.(ConnectionImpl.java.768) com.mysql.jdbc.JDBC4Connection.(JDBC4Connection.java.47) sun.reflect.GeneratedConstructorAccessor303.newInstance(null.-1) sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java.45) java.lang.reflect.Constructor.newInstance(Constructor.java.423) com.mysql.jdbc.Util.handleNewInstance(Util.java.403) com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java.385) com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java.323) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1666) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1732) com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java.2907)
    2024-11-29 14:06
  • CD20160914 CD20160914 回复 yzmpDJy83600781(提问者) 密码错误,检查一下账号或者密码
    2024-11-29 15:24
用户k6280494Lv6资深互助
发布于2024-11-29 11:11
起来装丶b啊Lv6初级互助
发布于2024-11-29 11:13
设计器安装目录下的lib目录里面有没有数据库的驱动包?
华莉星宸Lv7资深互助
发布于2024-11-29 11:13
注意驱动版本
[平台]MySQL数据连接 https://help.fanruan.com/finereport/doc-view-2560.html
XushuaisLv6初级互助
发布于2024-11-29 13:48
jdbc:mysql://hostname:port/database?generateSimpleParameterMetadata=true&useUnicode=true&characterEncoding=utf8&useSSL=false&serverTimezone=Asia/Shanghai
  • 6关注人数
  • 102浏览人数
  • 最后回答于:2024-11-29 13:48
