com.fr.workspace.engine.exception.RemoteDesignUnknownException: java.lang.reflect.UndeclaredThrowableException at com.fr.workspace.engine.convert.UnknownErrorConverter.convert(UnknownErrorConverter.java) at com.fr.workspace.engine.convert.UnknownErrorConverter.convert(UnknownErrorConverter.java) at com.fr.workspace.engine.convert.ExceptionConverter.convert(ExceptionConverter.java) at com.fr.env.handler.impl.UnexpectedHandler.handle(Unknown Source) at com.fr.env.handler.impl.UnexpectedHandler.handle(Unknown Source) at com.fr.env.handler.WorkspaceExceptionHandler.handle(Unknown Source) at com.fr.env.handler.WorkspaceExceptionHandler.handleInTest(Unknown Source) at com.fr.env.RemoteEnvPane$7.done(Unknown Source) at javax.swing.SwingWorker$5.run(SwingWorker.java:737) at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(SwingWorker.java:832) at sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112) at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker.java:842) at javax.swing.Timer.fireActionPerformed(Timer.java:313) at javax.swing.Timer$DoPostEvent.run(Timer.java:245) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233) at java.awt.Dialog.show(Dialog.java:1084) at java.awt.Component.show(Component.java:1671) at java.awt.Component.setVisible(Component.java:1623) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.fr.env.RemoteEnvPane.tryConnectRemoteEnv(Unknown Source) at com.fr.env.RemoteEnvPane.access$1100(Unknown Source) at com.fr.env.RemoteEnvPane$4.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289) at java.awt.Component.processMouseEvent(Component.java:6539) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6304) at java.awt.Container.processEvent(Container.java:2239) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2297) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476) at java.awt.Container.dispatchEventImpl(Container.java:2283) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84) at java.awt.EventQueue$4.run(EventQueue.java:733) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:730) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233) at java.awt.Dialog.show(Dialog.java:1084) at java.awt.Component.show(Component.java:1671) at java.awt.Component.setVisible(Component.java:1623) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.fr.design.EnvChangeEntrance.chooseEnv(Unknown Source) at com.fr.design.EnvChangeEntrance.chooseEnv(Unknown Source) at com.fr.design.actions.file.EditEnvAction.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886) at java.awt.Component.processMouseEvent(Component.java:6539) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6304) at java.awt.Container.processEvent(Container.java:2239) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2297) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476) at java.awt.Container.dispatchEventImpl(Container.java:2283) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84) at java.awt.EventQueue$4.run(EventQueue.java:733) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:730) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: java.lang.reflect.UndeclaredThrowableException at com.sun.proxy.$Proxy188.beat(Unknown Source) at com.fr.workspace.engine.client.FineWorkspaceTestClient.beatOnce(FineWorkspaceTestClient.java) at com.fr.workspace.engine.channel.WorkspaceChannelFactory.testForRpc(WorkspaceChannelFactory.java) at com.fr.workspace.engine.channel.WorkspaceChannelFactory.testConnection(WorkspaceChannelFactory.java) at com.fr.workspace.engine.client.FineWorkspaceConnector.testConnection(FineWorkspaceConnector.java) at com.fr.env.RemoteEnvPane$7.doInBackground(Unknown Source) at com.fr.env.RemoteEnvPane$7.doInBackground(Unknown Source) at javax.swing.SwingWorker$1.call(SwingWorker.java:295) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at javax.swing.SwingWorker.run(SwingWorker.java:334) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) Caused by: java.util.zip.ZipException: Not in GZIP format at java.util.zip.GZIPInputStream.readHeader(GZIPInputStream.java:165) at java.util.zip.GZIPInputStream. at java.util.zip.GZIPInputStream. at com.fr.serialization.GZipSerializerWrapper.deserialize(GZipSerializerWrapper.java) at com.fr.serialization.SerializerHelper.deserialize(SerializerHelper.java) at com.fr.workspace.engine.rpc.WorkspaceInvoker.invoke(WorkspaceInvoker.java) at com.fr.workspace.engine.rpc.WorkspaceProxyPool$1.invoke(WorkspaceProxyPool.java) ... 13 more 这是什么意思 是jar包不一样 |
