预览报错
java.lang.NullPointerException at com.fr.web.core.ReportSessionIDInfor.getReport2Show(Unknown Source) at com.fr.web.data.CalculatableAction.readContent(Unknown Source) at com.fr.web.core.A.$B.actionCMD(Unknown Source) at com.fr.web.core.WebActionsDispatcher.dealForActionCMD(Unknown Source) at com.fr.web.core.WebActionsDispatcher.dealForActionDefaultCmd(Unknown Source) at com.fr.web.core.WebActionsDispatcher.dealForActionCMD(Unknown Source) at com.fr.web.core.A.vC.process(Unknown Source) at com.fr.web.core.ReportDispatcher.dealWithOp(Unknown Source) at com.fr.web.core.ReportDispatcher.dealWeblet(Unknown Source) at com.fr.web.core.ReportDispatcher.dealWithRequest(Unknown Source) at com.fr.web.BaseServlet.doGet(Unknown Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java:596) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:428) at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:473) at
FineReport zjslh1999 发布于 2025-1-15 14:11
发布于2025-1-15 14:12(编辑于 2025-1-15 14:17)
你这什么都看不出来
先重启一下设计器吧,检查公式设置
实在不行,直接重新做一遍,边做边预览~
发布于2025-1-15 14:18
  • 23浏览人数
  • 最后回答于:2025-1-15 14:18
