var _token=""; var dataToSend = "username=abc&password=456"; var _url="get获取token的Api"; $.ajax({ type:"POST", url: _url, contentType: "application/x-www-form-urlencoded", headers: { "Content-Type": "application/x-www-form-urlencoded;charset=UTF-8" }, data: dataToSend, async: false, success: function (response) { //debugger console.log("服务器返回的数据:", response); if (response && response.data && 'usertoken' in response.data) { _token = response.data.usertoken; } }, error: function (xhr, status, error) { console.log("请求出错:", error); } }); if( _token==""){ alert("未获取到授权!"); return; } //获取32位随机码 function generateRandomCode() { const characters = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789'; const randomBytes = window.crypto.getRandomValues(new Uint8Array(32)); let randomCode = ''; for (let i = 0; i < 32; i++) { const index = randomBytes[i] % characters.length; randomCode += characters.charAt(index); } return randomCode; } const randomCode = generateRandomCode(); console.log(randomCode); // 对用户名和密码进行Base64编码,生成Basic Auth需要的认证字符串 var username = "sbt_fineReport"; var password = "init1234"; var credentials = btoa(username + ":" + password); //alert("base64加密后的值:"+credentials); // 创建Date对象获取当前时间 var currentDate = new Date(); // 获取年、月、日、时、分、秒,并进行格式化处理 var year = currentDate.getFullYear(); var month = ('0' + (currentDate.getMonth() + 1)).slice(-2); var day = ('0' + currentDate.getDate()).slice(-2); var hours = ('0' + currentDate.getHours()).slice(-2); var minutes = ('0' + currentDate.getMinutes()).slice(-2); var seconds = ('0' + currentDate.getSeconds()).slice(-2); // 拼接成指定格式的时间字符串 var formattedTime = year + month + day + hours + minutes + seconds; console.log(formattedTime); var _issubmit=false; var boxes = _g().getWidgetsByName("box"); var checkedBoxesInfo = []; var _index =16; var _flag =false; if (boxes.length > 0) { for (var i = 0; i < boxes.length; i++) { //debugger if (boxes[i].getValue() === true) { //对于置灰的跳过 _flag=false; var b2name="B"+(i+2); _flag = _g().getWidgetByCell(b2name).isEnabled(); //debugger if(!_flag) continue; _issubmit = true; var boxInfo = { //projectName: "任务推送", projectName: _g().getCellValue(0, _index, i+1),
//planName: "测试0222", planName: _g().getCellValue(0, _index+1, i+1),
taskSn: "2", //taskSn: _g().getCellValue(0, _index+2, i+1),
//taskName: "02", taskName: _g().getCellValue(0, _index+3, i+1),
//taskRemark: "测试11111", taskRemark: _g().getCellValue(0, _index+4, i+1),
//planStartDate: "2024-12-01", planStartDate: _g().getCellValue(0, _index+5, i+1),
//planEndDate: "2024-12-09", planEndDate: _g().getCellValue(0, _index+6, i+1),
//ownerId: "00005713", ownerId: _g().getCellValue(0, _index+7, i+1),
//auditorId: "00005713" auditorId: _g().getCellValue(0, _index+8, i+1) }; checkedBoxesInfo.push(boxInfo); //const jsonString = JSON.stringify(boxInfo); //console.info("boxInfo",boxInfo); //alert(jsonString); } } } var resultJson = JSON.stringify(checkedBoxesInfo); console.info("组装的record节点的JSON",resultJson); if(!_issubmit){ alert("请勾选要推送的信息!"); return; } //alert(resultJson); //debugger var _url="save业务保存API"; var a={ common:{ busid: '10000000', instld: randomCode, sender: '1', receiver:'2', request_time: formattedTime }, business: { record: checkedBoxesInfo } }; console.info("组装的请求JSON : ",a); $.ajax({ url:_url, type: "POST", data:JSON.stringify(a), dataType: "json", contentType: "application/json", headers: { "Content-Type": "application/json;charset=UTF-8", "Authorization":credentials, "usertoken":_token, "itgAuthorizationKey":"123456" }, timeout: 5000, async: false, success: function (response) { debugger console.info("response",response); // 检查必要的节点是否存在 if (!response.business ||!response.common ||!response.common.returnMsg ||!response.common.returnStatus) { alert("推送失败!"); return; } if (response.common.returnStatus === "S") { _g().verifyAndWriteReport(); alert("推送完成!"); location.reload(); } else { alert(response.common.returnMsg); } }, error: function (xhr, status, error) { //debugger console.info("请求失败:" + error); alert("推送失败"); } }); |
最佳回答 |
