下拉框能展示数据但无法进行模糊查询为什么
卡来源字段是card_source,sql如下
为什么下拉框只能展示数据却不能进行正常的筛选模糊查询
FineReport fanruan大头兵 发布于 2025-2-15 14:08
发布于2025-2-15 14:49(编辑于 2025-2-15 14:52)
ds1数据集,这个用来单元格展示数据的
select
t.*
from (
SELECT
sd.email,
consume_phone phone,
case hg.group_card_kind when '1' then '赠洗卡' else '现金卡' end as card_type,
CASE WHEN hg.group_card_type IN ('X', 'Y', 'V', 'T') THEN '门市充值'
ELSE '团单'END as card_source,
hg.group_name as group_name,
'消费' operatype,
COUNT(hs.consume_card_kind ) AS times,
IFNULL(sum(IF(hs.consume_status='+',(hs.consume_amount),-(hs.consume_amount))),0) money,
sum(hs.consume_gift_amount) as gift_money,
(IFNULL(sum(IF(hs.consume_status='+',(hs.consume_amount),-(hs.consume_amount))),0)-sum(hs.consume_gift_amount)) as last_money
FROM
qianxun_wash_consume hs
LEFT JOIN qianxun_wash_groupcard hg ON (hs.consume_phone = hg.group_phone and hs.consume_card_kind=hg.group_card_kind)
LEFT JOIN sys_dept sd on sd.dept_id=hg.create_dept
WHERE
consume_subtract_card != '0'
and hs.consume_card_type IS NOT NULL
and hs.create_unit='101'
and hs.consume_card_type <> ' '
AND hs.consume_type IN
( '200', '220' )
${if(len(startdate)>0," and DATE_FORMAT(hs.create_time, '%Y-%m-%d') >='"+startdate+"'","")}
${if(len(enddate)>0," and DATE_FORMAT(hs.create_time, '%Y-%m-%d') ='"+times+"'","")}
) t
where 1=1
${if(len(card_source)=0,"","and t.card_source='"+card_source+"'")}
ORDER BY t.times DESC
ds2数据集2  或者自定义数据字典用来筛选card_source
只返回    门市充值  与  团单 两个值就行了!!!
  • fanruan大头兵 fanruan大头兵(提问者) 用来自定义数据字典的数据集,我是这样写的还是不行select * from(
    select DISTINCT case hg.group_card_type when (hg.group_card_type IN ( 'X', 'Y','V' ,'T') ) then '门市充值' else '团单' end as card_source from qianxun_wash_groupcard hg where hg.create_unit='101'
    ) hg
    where 1=1
    ${if(len(card_source)>0," and hg.card_source ='"+card_source+"'","")}
    2025-02-15 15:05
  • CD20160914 CD20160914 回复 fanruan大头兵(提问者) 你这个只是条件 ,不用写了,直接按我说的配置两个固定值就行了!!!你肯定还没有到下拉框的意思!!
    2025-02-15 15:17
  • CD20160914 CD20160914 回复 fanruan大头兵(提问者) 这个语句不要加参数。就直接配置ds2为两个固定值,或者直接按我截图说的只配置下拉框的数据字典就行了,同时ds1复制我写的就可以了!!!
    2025-02-15 15:18
  • fanruan大头兵 fanruan大头兵(提问者) 回复 CD20160914 直接配置数据字典也是不能筛选,只有下拉框展示
    2025-02-15 15:24
  • CD20160914 CD20160914 回复 fanruan大头兵(提问者) 你要不加我,直接远程吧。
    2025-02-15 15:27
发布于2025-2-15 14:10(编辑于 2025-2-15 14:13)
下拉框/下拉复选框/下拉树的模糊搜索
select * from(
) hg
where 1=1
  • fanruan大头兵 fanruan大头兵(提问者) SELECT
    sd.email,
    consume_phone phone, case hg.group_card_kind when '1' then '赠洗卡' else '现金卡' end as card_type,
    CASE
    ELSE '团单'
    END as card_source,
    hg.group_name group_name,
    '消费' operatype,
    COUNT( hs.consume_card_kind ) AS times,
    FROM
    WHERE
    consume_subtract_card != '0' and hs.consume_card_type IS NOT NULL
    -- AND CAST(
    -- consume_subtract_card AS DECIMAL ( 10, 2 ))> 0
    ( '200', '220' )
    ${if(startdate!=''," and DATE_FORMAT(hs.create_time, '%Y-%m-%d') >='"+startdate+"'","")}
    ${if(enddate!=''," and DATE_FORMAT(hs.create_time, '%Y-%m-%d') ='"+times+"'","")}
    ORDER BY
    times DESC这是我的sql只能展示下拉框内容,不能搜索为什么
    2025-02-15 14:21
  • 用户k6280494 用户k6280494 回复 fanruan大头兵(提问者) 你下拉框内容得单独一个数据集,不能跟报表内容共用?
    2025-02-15 14:27
  • fanruan大头兵 fanruan大头兵(提问者) 回复 用户k6280494 好,我试试
    2025-02-15 14:31
  • 用户k6280494 用户k6280494 回复 fanruan大头兵(提问者) 你要筛选CASE
    ELSE '团单'
    END as card_source,这个字段外面就要在套一个查询语句
    select * from(
    ) hg
    where 1=1
    2025-02-15 14:33
  • 70浏览人数
  • 最后回答于:2025-2-15 14:52
