设计器mongodb连接报错
ava.util.concurrent.TimeoutException
java.util.concurrent.FutureTask.get(FutureTask.java.205)
com.fr.data.operator.DataOperator.testConnectionWithException(DataOperator.java.-1)
com.fr.design.data.datapane.connect.DatabaseConnectionPane$TestConnectionWorker.doInBackground(DatabaseConnectionPane.java.454)
com.fr.design.data.datapane.connect.DatabaseConnectionPane$TestConnectionWorker.doInBackground(DatabaseConnectionPane.java.432)
javax.swing.SwingWorker$1.call(SwingWorker.java.295)
java.util.concurrent.FutureTask.run(FutureTask.java.266)
javax.swing.SwingWorker.run(SwingWorker.java.334)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java.624)
java.lang.Thread.run(Thread.java.750)
FineReport yzm158840 发布于 2025-3-28 14:33
发布于2025-3-28 14:35
插件试试吧
MongoDB数据库插件 https://help.fanruan.com/finereport/doc-view-1413.html
发布于2025-3-28 14:36
重启一下设计器在连接看看
  • 15浏览人数
  • 最后回答于:2025-3-28 14:36
