CD20160914Lv8专家互助发布于2025-5-9 09:12(编辑于 2025-5-9 09:25)
那你接收的报表中要用 字段名称 in ('${参数名称}') 而且单元格的格式要形成类似 AA','BB 这样的格式!
SELECT * FROM loan_list WHERE 1 = 1 AND zdel_flag IS NULL ${if(len(ZLONG) == 0,""," AND CONCAT(ZRDATE,',',zrequester_id,',',ZPROD_TYPE) = '" + ZLONG + "'")} ${if(len(zrequester_id) == 0,""," AND zrequester_id = '" + zrequester_id + "'")} ${if(len(zprod_type) == 0,""," AND zprod_type = '" + zprod_type + "'")} ${if(len(申请日期) == 0,""," AND DATE(zrdate) = '" + 申请日期 + "'")} ${if(len(zid) == 0,""," AND zid in('" + zid + "')")}
nesy(提问者)
- SELECT *
FROM loan_list
WHERE 1 = 1
${if(len(zid) == 0,""," AND zid = '" + zid + "'")}
ORDER BY ZRDATE, zrequester_id, ZID这是超级链接报表的数据集
CD20160914 回复 nesy(提问者)
- 你现在打zid打印出来看它的格式是如何的。你要用in呀!!
- 改成上面的语句,我重新编辑了。而且你的zid为多个值的时候,要看看它的格式是不是在单元格为 AA','BB 不要最前面与最后面的单引号
nesy(提问者) 回复 CD20160914
- 这不应该是zid报错啊,链接用的也不是zid
- 你先按我说的改呀,你现在传的参数是什么呢?到底是什么多个
