日期传参
year、month 、day 三个参数从另一页面传值过来,day 为空时,过滤年
月的值,否则业务日期 就等 三个参数拼在一起的值。这么写是错误的
${if(len('${day}') == 0,   " 年月='${year}-${month}'",   " AND 业务日期='${year}-${month}-${day}'"
FineReport 库兜南 发布于 2025-7-2 09:52
发布于2025-7-2 09:54(编辑于 2025-7-2 09:55)
${if(len(day) == 0,   "AND 年月='"+year+"-"+month+"'",   " AND 业务日期='"+year+"-"+month+"-"+day+"'")}
  • 库兜南 库兜南(提问者) 如果要用日期区间 前面要 在day -1 怎么写?${if(len(day) == 0, "", " AND TO_CHAR(a.FBIZDATE,'yyyy-mm-dd')>='"+year+"-"+month+"-"+day+"'")}
    ${if(len(day) == 0, "", " AND TO_CHAR(a.FBIZDATE,'yyyy-mm-dd')<='"+year+"-"+month+"-"+day+"'")}
    2025-07-02 16:13
  • snrtuemc snrtuemc 回复 库兜南(提问者) 直接
    ${if(len(day) == 0, "", " AND TO_CHAR(a.FBIZDATE,'yyyy-mm-dd')<='"+year+"-"+month+"-"+(day-1)+"'")}
    但是注意,你的day需要设置格式,如果是04这个格式,可以改成
    ${if(len(day) == 0, "", " AND TO_CHAR(a.FBIZDATE,'yyyy-mm-dd')<='"+year+"-"+month+"-"+format(day*1-1,"00")+"'")}
    2025-07-02 16:15
  • 库兜南 库兜南(提问者) 回复 snrtuemc 如果是跨月 呢怎么修改?${if(len(day) == 0, "", " AND TO_CHAR(a.FBIZDATE,'yyyy-mm-dd')>='"+year+"-"+month+"-"+format(day*1-1,"00")+"'")}
    ${if(len(day) == 0, "", " AND TO_CHAR(a.FBIZDATE,'yyyy-mm-dd')<='"+year+"-"+month+"-"+format(day*1,"00")+"'")}
    2025-07-07 10:44
runnerLv7资深互助
发布于2025-7-2 09:54
${if(len('day') == 0,   " 年月='year'+'-'+'month'",   " AND 业务日期='year'+'-'+'month'+'-'+'day'"
发布于2025-7-2 09:54(编辑于 2025-7-2 09:56)
${if(len(day) == 0,   " 年月='"+CONCATENATE(year,'-',month+"'",   " AND 业务日期='"+CONCATENATE(year,'-',month,'-',day}+"'"
  • 54浏览人数
  • 最后回答于:2025-7-2 09:56
