求解FineReport公式
读取G8I8K8M8四个单元格里面的中文字符,四个表格里的数据,不是规范的,有空数据,有空格符号顿号冒号等等符号,只读取中文比对,只要就是比对名字,四个单元格两两比对,存在连续两个字相同的,结果赋值是,否则赋值否
FineReport 帆软用户NdPyJlXnUw 发布于 2025-7-11 11:13
发布于2025-7-11 11:15(编辑于 2025-7-11 11:15)
改成
=if(JOINARRAY(split(G8,"[^\\u4e00-\\u9FFF]"),"")=JOINARRAY(split(I8,"[^\\u4e00-\\u9FFF]"),"")||JOINARRAY(split(I8,"[^\\u4e00-\\u9FFF]"),"")=JOINARRAY(split(K8,"[^\\u4e00-\\u9FFF]"),"")||JOINARRAY(split(K8,"[^\\u4e00-\\u9FFF]"),"")=JOINARRAY(split(M8,"[^\\u4e00-\\u9FFF]"),""),"是","否")
也可以OR写法
=if(or(JOINARRAY(split(G8,"[^\\u4e00-\\u9FFF]"),"")=JOINARRAY(split(I8,"[^\\u4e00-\\u9FFF]"),""),JOINARRAY(split(I8,"[^\\u4e00-\\u9FFF]"),"")=JOINARRAY(split(K8,"[^\\u4e00-\\u9FFF]"),""),JOINARRAY(split(K8,"[^\\u4e00-\\u9FFF]"),"")=JOINARRAY(split(M8,"[^\\u4e00-\\u9FFF]"),"")),"是","否")
发布于2025-7-11 11:15
先用这个提取汉字
=JOINARRAY(split(B3,"[^\u4e00-\u9FFF]"),"")
在进行比较
  • 30浏览人数
  • 最后回答于:2025-7-11 11:15
