这里有两个表头,第二个表头J1的上父格是G1两个表头分别是两个字段扩展的。我能自定义这两个表头的排列顺序吗,比如表头1扩展出来的值有 A,B,C;表头2扩展出来的是a,b,c;展示出来后要求是A,a,C,b,c,B;类似这样。 目前我是通过sql:ORDER BY FIELD(BU2,"IBC","EQ","FICC","AMMF","CCM","WM","BO","INT","区域化"),FIELD(BU1,"IBC","EQ","FICC","AMMF","CCM","WM","BO","INT","区域化"),FIELD(division1,"EQ","SI","AM","MF","PCI","DSA","FM"),FIELD(division2,"EQ","SI","AM","MF","PCI","DSA","FM") 但是有个问题:BU2='BO'的时候division2的值可能是:PCI,DSA,FM;现在的效果是FM会展示在INT前面,想要实现的是PCI,DSA在INT前面,FM在INT后面,怎么实现? |
