远程设计连接发生未知错误,没有错误代码,
com.fr.workspace.engine.exception.RemoteDesignUnknownException: com.fr.invoke.ReflectException: java.lang.reflect.InvocationTargetException
at com.fr.workspace.engine.convert.UnknownErrorConverter.convert(UnknownErrorConverter.java)
at com.fr.workspace.engine.convert.ExceptionConverter.convert(ExceptionConverter.java)
at com.fr.env.handler.impl.UnexpectedHandler.handle(UnexpectedHandler.java:22)
at com.fr.env.handler.impl.UnexpectedHandler.handle(UnexpectedHandler.java:16)
at com.fr.env.handler.WorkspaceExceptionHandler.handle(WorkspaceExceptionHandler.java:58)
at com.fr.env.handler.WorkspaceExceptionHandler.handleInStart(WorkspaceExceptionHandler.java:90)
at com.fr.design.EnvChangeEntrance.dealEvnExceptionWhenStartDesigner(EnvChangeEntrance.java:572)
at com.fr.start.module.DesignerWorkspaceProvider.start(DesignerWorkspaceProvider.java:60)
at com.fr.module.engine.strategy.ParentFirstStrategy.doStart(ParentFirstStrategy.java)
at com.fr.module.engine.strategy.AbstractInvokeSubStrategy.start(AbstractInvokeSubStrategy.java)
at com.fr.module.engine.FineModule$FineModuleRunner.executeStart(FineModule.java)
at com.fr.stable.lifecycle.AbstractLifecycle.start(AbstractLifecycle.java)
at com.fr.module.engine.FineModule$FineModuleRunner.start(FineModule.java)
at com.fr.module.engine.FineModule.start(FineModule.java)
at com.fr.module.engine.strategy.AbstractInvokeSubStrategy.startSub(AbstractInvokeSubStrategy.java)
at com.fr.module.engine.strategy.SubFirstStrategy.doStart(SubFirstStrategy.java)
at com.fr.start.util.DesignerStartupPageUtil.enterWorkspace(DesignerStartupPageUtil.java:18)
at com.fr.start.module.optimized.DesignerStartupPageActivator.launchAfterWarmup(DesignerStartupPageActivator.java:163)
at com.fr.start.module.optimized.DesignerStartupPageActivator.lambda$null$3(DesignerStartupPageActivator.java:115)
at com.fr.startup.ui.StartupPageWindow$4.doInBackground(StartupPageWindow.java:251)
at com.fr.startup.ui.StartupPageWindow$4.doInBackground(StartupPageWindow.java:248)
at javax.swing.SwingWorker$1.call(SwingWorker.java:295)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at javax.swing.SwingWorker.run(SwingWorker.java:334)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.fr.invoke.ReflectException: java.lang.reflect.InvocationTargetException
at com.fr.invoke.Reflect.on(Reflect.java:751)
at com.fr.invoke.Reflect.call(Reflect.java:412)
at com.fr.workspace.engine.rpc.WorkspaceProxyPool.defaultExceptionHandler(WorkspaceProxyPool.java)
at com.fr.workspace.engine.rpc.WorkspaceProxyPool.exceptionHandler(WorkspaceProxyPool.java)
at com.fr.workspace.engine.rpc.WorkspaceProxyPool.access$200(WorkspaceProxyPool.java)
at com.fr.workspace.engine.rpc.WorkspaceProxyPool$1.invoke(WorkspaceProxyPool.java)
at com.sun.proxy.$Proxy26.getInterval(Unknown Source)
at com.fr.workspace.engine.client.FineWorkspaceClient.startHeartBeat(FineWorkspaceClient.java)
at com.fr.workspace.engine.client.FineWorkspaceClient.<init>(FineWorkspaceClient.java)
at com.fr.workspace.engine.client.FineWorkspaceConnector.connect(FineWorkspaceConnector.java)
at com.fr.design.env.DesignerWorkspaceGenerator$1.call(DesignerWorkspaceGenerator.java:53)
at com.fr.design.env.DesignerWorkspaceGenerator$1.call(DesignerWorkspaceGenerator.java:50)
... 3 more
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.fr.invoke.Reflect.on(Reflect.java:748)
... 15 more
Caused by: java.lang.UnsupportedOperationException
at com.fr.workspace.engine.client.heartbeart.CompatibleWorkspaceHeartbeat.getInterval(CompatibleWorkspaceHeartbeat.java)
... 20 more
FineReport hasn_z 发布于 2025-7-25 10:57
发布于2025-7-25 10:59(编辑于 2025-7-25 10:59)
本地设计器与服务器的jar包版本不一致吧
远程设计常见问题 https://help.fanruan.com/finereport/doc-view-3925.html
  • hasn_z hasn_z(提问者) 我已经在本地和服务器两边分别在线升级为最新了,版本一致,还是连不上。
    2025-07-25 11:03
  • 华莉星宸 华莉星宸 回复 hasn_z(提问者) 难道是你们禁止远程设计?
    看看其他同事可以远程设计吗
    2025-07-25 11:07
  • hasn_z hasn_z(提问者) 回复 华莉星宸 可以远程设计,我就是管理员,感觉不是JAR包的问题
    2025-07-25 16:34
  • 29浏览人数
  • 最后回答于:2025-7-25 10:59
