经验证筛选后的值是对的,初始界面值错的,但是不知道为什么会出现这种情况
代码 select net_weight ,updated_on,product_code,product_name,storage,pallet_id from ( SELECT m.*, @row_number := IF(@current_pallet = pallet_id, @row_number + 1, 1) AS rn, @current_pallet := pallet_id FROM material_warehousing_record m, (SELECT @row_number := 0, @current_pallet := NULL) AS vars WHERE 1=1 and storage in ("AccessoriesStorage","RubberStorage","SteelCord","CharcoalStorage","TextileStorage") ${if(len(结束日期) == 0,"","and m.updated_on BETWEEN '" + format(开始日期,'YYYY-MM-dd') + "' AND '"+format(DATEDELTA(结束日期,1),'YYYY-MM-dd')+"'")} ${if(len(库房) == 0,"","and m.storage in ('" + 库房 + "')")} ${if(len(物料名称) == 0,"","and m.product_name like '%" + 物料名称 + "%'")} ${if(len(物料规格) == 0,"","and m.product_spec like '%" + 物料规格 + "%'")} ${if(len(物料编码) == 0,"","and m.product_code like '%" + 物料编码 + "%'")} ORDER BY pallet_id, updated_on DESC) a where 1=1 and rn=1 ${if(len(结束日期) == 0,"","and a.updated_on BETWEEN '" + format(开始日期,'YYYY-MM-dd') + "' AND '"+format(DATEDELTA(结束日期,1),'YYYY-MM-dd')+"'")} ${if(len(库房) == 0,"","and a.storage in ('" + 库房 + "')")} ${if(len(物料名称) == 0,"","and a.product_name like '%" + 物料名称 + "%'")} ${if(len(物料规格) == 0,"","and a.product_spec like '%" + 物料规格 + "%'")} ${if(len(物料编码) == 0,"","and a.product_code like '%" + 物料编码 + "%'")} |
