sql数据关联问题
字段u2至x4没有值,可能什么原因:
SELECT
    r.b AS b1,
    r.c AS c1,
    r.d AS d1,
    r.e AS e1,
    r.f AS f1,
    r.g AS g1,
    r.h AS h1,
    r.i AS i1,
    r.j AS j1,
    r.k AS k1,
    r.l AS l1,
    CASE
        WHEN r.j::text != '2' THEN
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.lfy_actual_ytd_display ELSE a.lfy_actual_ytd_display END
        ELSE NULL
    END AS u2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cfy_budget_ytd_display ELSE a.cfy_budget_ytd_display END
        ELSE NULL
    END AS v2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cfy_f1_ytd_display ELSE a.cfy_f1_ytd_display END
        ELSE NULL
    END AS w2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cfy_f2_ytd_display ELSE a.cfy_f2_ytd_display END
        ELSE NULL
    END AS x2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.nfy_budget_ytd_display ELSE a.nfy_budget_ytd_display END
        ELSE NULL
    END AS z2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.ly_actual_mtd_display ELSE a.ly_actual_mtd_display END
        ELSE NULL
    END AS o3,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cy_budget_mtd_display ELSE a.cy_budget_mtd_display END
        ELSE NULL
    END AS p3,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cy_actual_mtd_display ELSE a.cy_actual_mtd_display END
        ELSE NULL
    END AS q3,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.ly_actual_ytd_display ELSE a.ly_actual_ytd_display END
        ELSE NULL
    END AS o4,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cy_budget_ytd_display ELSE a.cy_budget_ytd_display END
        ELSE NULL
    END AS p4,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cy_actual_ytd_display ELSE a.cy_actual_ytd_display END
        ELSE NULL
    END AS q4,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cfyf1_lfyact_fullyear_display ELSE a.cal_contvar_cfyf1_lfyact_fullyear_display END
        ELSE NULL
    END AS ai2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cfyf1_cfybud_fullyear_display ELSE a.cal_contvar_cfyf1_cfybud_fullyear_display END
        ELSE NULL
    END AS aj2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cfyf2_lfyact_fullyear_display ELSE a.cal_contvar_cfyf2_lfyact_fullyear_display END
        ELSE NULL
    END AS ak2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cfyf2_cfybud_fullyear_display ELSE a.cal_contvar_cfyf2_cfybud_fullyear_display END
        ELSE NULL
    END AS al2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cfyf2_cfyf1_fullyear_display ELSE a.cal_contvar_cfyf2_cfyf1_fullyear_display END
        ELSE NULL
    END AS am2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_nfybud_cfyf2_fullyear_display ELSE a.cal_contvar_nfybud_cfyf2_fullyear_display END
        ELSE NULL
    END AS aq2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cfybud_lfybud_fullyear_display ELSE a.cal_contvar_cfybud_lfybud_fullyear_display END
        ELSE NULL
    END AS ar2,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cyact_lyact_mtd_display ELSE a.cal_contvar_cyact_lyact_mtd_display END
        ELSE NULL
    END AS w3,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cyact_cybud_mtd_display ELSE a.cal_contvar_cyact_cybud_mtd_display END
        ELSE NULL
    END AS x3,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cyact_lyact_ytd_display ELSE a.cal_contvar_cyact_lyact_ytd_display END
        ELSE NULL
    END AS w4,
    CASE
            CASE WHEN r.g = 'Non-allocated structure costs' THEN b.cal_contvar_cyact_cybud_ytd_display ELSE a.cal_contvar_cyact_cybud_ytd_display END
        ELSE NULL
    END AS x4
FROM raw_finerpt_config_vprpt_displaysetting r
LEFT JOIN apv_d4f_vw_trans_vmr_vm0001_0800800_op_ori_dis a
    ON a.vmr_code_entity = r.c
    AND a.vmr_code_kfi = 'Vec_15'
    AND a.cy_cal_vmr_datep_yyyy_mm_str = '${ymonth}'
    AND a.vmr_type_data = '${vmr_type_data}'
    AND a.config_accesscode LIKE '%${config_accesscode}%'
    AND a.type_displaycurr = '${type_displaycurr}'
    AND a.cmentity_type_buzunit = '${cmentity_type_buzunit}'
LEFT JOIN (
    SELECT
        t1.cmentity_type_buzunit,
        t1.vmr_type_data,
        t1.type_displaycurr,
        t1.cy_cal_vmr_datep_yyyy_mm_str,
        SUM(t1.lfy_actual_ytd_display) AS lfy_actual_ytd_display,
        SUM(t1.cfy_budget_ytd_display) AS cfy_budget_ytd_display,
        SUM(t1.cfy_f1_ytd_display) AS cfy_f1_ytd_display,
        SUM(t1.cfy_f2_ytd_display) AS cfy_f2_ytd_display,
        SUM(t1.nfy_budget_ytd_display) AS nfy_budget_ytd_display,
        SUM(t1.ly_actual_mtd_display) AS ly_actual_mtd_display,
        SUM(t1.cy_budget_mtd_display) AS cy_budget_mtd_display,
        SUM(t1.cy_actual_mtd_display) AS cy_actual_mtd_display,
        SUM(t1.ly_actual_ytd_display) AS ly_actual_ytd_display,
        SUM(t1.cy_budget_ytd_display) AS cy_budget_ytd_display,
        SUM(t1.cy_actual_ytd_display) AS cy_actual_ytd_display,
        SUM(t1.cal_contvar_cfyf1_lfyact_fullyear_display) AS cal_contvar_cfyf1_lfyact_fullyear_display,
        SUM(t1.cal_contvar_cfyf1_cfybud_fullyear_display) AS cal_contvar_cfyf1_cfybud_fullyear_display,
        SUM(t1.cal_contvar_cfyf2_lfyact_fullyear_display) AS cal_contvar_cfyf2_lfyact_fullyear_display,
        SUM(t1.cal_contvar_cfyf2_cfybud_fullyear_display) AS cal_contvar_cfyf2_cfybud_fullyear_display,
        SUM(t1.cal_contvar_cfyf2_cfyf1_fullyear_display) AS cal_contvar_cfyf2_cfyf1_fullyear_display,
        SUM(t1.cal_contvar_nfybud_cfyf2_fullyear_display) AS cal_contvar_nfybud_cfyf2_fullyear_display,
        SUM(t1.cal_contvar_cfybud_lfybud_fullyear_display) AS cal_contvar_cfybud_lfybud_fullyear_display,
        SUM(t1.cal_contvar_cyact_lyact_mtd_display) AS cal_contvar_cyact_lyact_mtd_display,
        SUM(t1.cal_contvar_cyact_cybud_mtd_display) AS cal_contvar_cyact_cybud_mtd_display,
        SUM(t1.cal_contvar_cyact_lyact_ytd_display) AS cal_contvar_cyact_lyact_ytd_display,
        SUM(t1.cal_contvar_cyact_cybud_ytd_display) AS cal_contvar_cyact_cybud_ytd_display
    FROM apv_d4f_vw_trans_vmr_vm0001_0800800_op_ori_dis AS t1
    WHERE (t1.vmr_code_kfi = 'Vec_11' AND t1.cmentity_type_buz <> 'Holding')
        OR (t1.vmr_code_kfi = 'Vec_14' AND t1.cmentity_type_buz = 'Holding')
    GROUP BY
        t1.vmr_type_data,
) b ON b.cmentity_type_buzunit = '${cmentity_type_buzunit}'
    AND b.vmr_type_data = '${vmr_type_data}'
    AND b.type_displaycurr = '${type_displaycurr}'
    AND b.cy_cal_vmr_datep_yyyy_mm_str = '${ymonth}'
WHERE r.k = 'Ctrl EBITDA'
    AND r.j::text != '0'
    AND r.year = LEFT('${ymonth}', 4)
    AND (
        (r.j::text != '2')
        OR
        (r.j::text = '2' AND r.b LIKE '%${config_accesscode}%')
ORDER BY l1
SQL 帆软用户Dcu3auzqkx 发布于 2025-9-24 09:58
梦似幻亦真Lv3初级互助
发布于2025-11-6 16:08
CASE WHEN 条件 THEN 显示内容  WHEN 条件 THEN 显示内容 ELSE '显示内容' END
正确写法:
CASE WHEN r.j::text != '2' AND r.g = 'Non-allocated structure costs' THEN b.lfy_actual_ytd_display
         WHEN r.j::text != '2' AND r.g != 'Non-allocated structure costs' THEN a.lfy_actual_ytd_display
         ELSE NULL
END AS u2
  • 13浏览人数
  • 最后回答于:2025-11-6 16:08
