记录下,用户角色与报表对应关系
参考:用户权限查询 https://help.fanruan.com/finereport/doc-view-3882.html及评论区帆软用户Ad1yed0xrc的思路。 没涉及部门,区别:union all,NOT EXISTS中一个是 A.用户ID=f1.roleid,一个是A.roleid=f1.roleid
WITH staff AS (
SELECT
u.ID 用户ID,
u.USERNAME 用户名,
u.REALNAME 姓名,
rc.ID 角色ID,
rc.NAME 角色 ,
rm.roleid
FROM
FINEBI11.FINE_USER u
LEFT JOIN FINEBI11.FINE_USER_ROLE_MIDDLE rm ON u.ID = rm.userId
LEFT JOIN FINEBI11.FINE_CUSTOM_ROLE rc ON rm.ROLETYPE = 2
AND rm.ROLEID = rc.ID
WHERE
1 = 1
AND USERNAME = 'test'
B AS (
select
F.roleid,
f.AUTHORITYTYPE,
case when f.AUTHORITYTYPE='1' then '查看权限'
when f.AUTHORITYTYPE='2' then '授权权限'
when f.AUTHORITYTYPE='3' then '编辑权限'
when f.AUTHORITYTYPE='4' then '数据连接管理权限'
when f.AUTHORITYTYPE='101' then 'FineReport 模板认证权限'
when f.AUTHORITYTYPE='102' then 'FineReport 模板查看权限'
when f.AUTHORITYTYPE='103' then 'FineReport 模板填报权限'
when f.AUTHORITYTYPE='201' then '业务包使用权限'
when f.AUTHORITYTYPE='202' then '业务包管理权限'
when f.AUTHORITYTYPE='203' then 'BI报表导出权限'
when f.AUTHORITYTYPE='204' then 'BI仪表板分享权限'
when f.AUTHORITYTYPE='205' then 'BI模板认证权限'
when f.AUTHORITYTYPE='206' then 'BI模板查看权限'
when f.AUTHORITYTYPE='207' then 'BI模板导出权限'
when f.AUTHORITYTYPE='208' then 'BI仪表板分享角色控制权限'
when f.AUTHORITYTYPE='209' then 'BI仪表板分享功能权限'
when f.AUTHORITYTYPE='210' then 'BI仪表板公共链接功能权限' end 权限类型,
case when f.ROLETYPE='1' then '部门'
when f.ROLETYPE='2' then '角色'
when f.ROLETYPE='3' then '用户'
when f.ROLETYPE='4' then '职务' end 类型,
a.ID,
a.DISPLAYNAME 名称,
a.SORTINDEX,
a.PARENTID PARENTID0,
b.PARENTID PARENTID1,
b.DISPLAYNAME AS DISPLAYNAME1,
c.PARENTID PARENTID2,
c.DISPLAYNAME AS DISPLAYNAME2,
c.SORTINDEX AS SORTINDEX2,
d.PARENTID PARENTID3,
d.DISPLAYNAME AS DISPLAYNAME3,
e.PARENTID PARENTID4,
e.DISPLAYNAME AS DISPLAYNAME4,
f.PARENTID PARENTID5,
f.DISPLAYNAME AS DISPLAYNAME5,
g.PARENTID PARENTID6,
g.DISPLAYNAME AS DISPLAYNAME6,
h.PARENTID PARENTID7,
h.DISPLAYNAME AS DISPLAYNAME7,
case when a.EXPANDTYPE='1' then '平台管理系统节点'
when a.EXPANDTYPE='2' then '首页'
when a.EXPANDTYPE='3' then '目录'
when a.EXPANDTYPE='5' then '链接'
when a.EXPANDTYPE='6' then '文件'
when a.EXPANDTYPE='101' then '上报流程'
when a.EXPANDTYPE='102' then ' FineReport报表'
when a.EXPANDTYPE='201' then ' BI报表'
 end 权限目录类型
from FINEBI11.FINE_AUTHORITY_OBJECT a
left join FINEBI11.FINE_AUTHORITY_OBJECT b on a.PARENTID=b.id
left join FINEBI11.FINE_AUTHORITY_OBJECT c on b.PARENTID=c.id
left join FINEBI11.FINE_AUTHORITY_OBJECT d on c.PARENTID=d.id
left join FINEBI11.FINE_AUTHORITY_OBJECT e on d.PARENTID=e.id
left join FINEBI11.FINE_AUTHORITY_OBJECT f on e.PARENTID=f.id
left join FINEBI11.FINE_AUTHORITY_OBJECT g on f.PARENTID=g.id
left join FINEBI11.FINE_AUTHORITY_OBJECT h on g.PARENTID=h.id
 join FINEBI11.FINE_AUTHORITY f on f.AUTHORITY=2 and (a.id=f.AUTHORITYENTITYID or a.PARENTID=f.AUTHORITYENTITYID or b.PARENTID=f.AUTHORITYENTITYID or c.PARENTID=f.AUTHORITYENTITYID
or d.PARENTID=f.AUTHORITYENTITYID or e.PARENTID=f.AUTHORITYENTITYID)
where AUTHORITYTYPE = '1' AND a.DEVICETYPE NOT IN ('0','4')
-- order by a.PARENTID,a.SORTINDEX
SELECT
FROM
SELECT
FROM
staff A
JOIN B B ON A.用户ID = B.roleid
WHERE
1 = 1
AND NOT EXISTS (select 1 from  FINEBI11.FINE_AUTHORITY f1 where f1.AUTHORITY=1 and (B.id=f1.AUTHORITYENTITYID or B.PARENTID0=f1.AUTHORITYENTITYID or B.PARENTID1=f1.AUTHORITYENTITYID or B.PARENTID2=f1.AUTHORITYENTITYID or B.PARENTID3=f1.AUTHORITYENTITYID or B.PARENTID4=f1.AUTHORITYENTITYID  or B.PARENTID5=f1.AUTHORITYENTITYID or B.PARENTID6=f1.AUTHORITYENTITYID or B.PARENTID7=f1.AUTHORITYENTITYID) and A.用户ID=f1.roleid and B.AUTHORITYTYPE=f1.AUTHORITYTYPE)
UNION ALL
SELECT
FROM
staff A
JOIN B B ON A.角色ID = B.roleid
WHERE
1 = 1
AND NOT EXISTS (select 1 from  FINEBI11.FINE_AUTHORITY f1 where f1.AUTHORITY=1 and (B.id=f1.AUTHORITYENTITYID or B.PARENTID0=f1.AUTHORITYENTITYID or B.PARENTID1=f1.AUTHORITYENTITYID or B.PARENTID2=f1.AUTHORITYENTITYID or B.PARENTID3=f1.AUTHORITYENTITYID or B.PARENTID4=f1.AUTHORITYENTITYID  or B.PARENTID5=f1.AUTHORITYENTITYID or B.PARENTID6=f1.AUTHORITYENTITYID or B.PARENTID7=f1.AUTHORITYENTITYID) and A.roleid=f1.roleid and B.AUTHORITYTYPE=f1.AUTHORITYTYPE)
) t1
FineReport 1592 发布于 2025-11-11 10:03
1592Lv6高级互助
发布于2025-11-11 10:03
参考上述
  • Z4u3z1 Z4u3z1 你这是违规行为,小心兔子罚你。记录你可以使用其它方式
    2025-11-11 10:04
  • 1592 1592(提问者) 回复 Z4u3z1 是吗,那我看看怎么删掉
    2025-11-11 10:05
  • LOE LOE 回复 Z4u3z1 自己采纳自己的反正也没有钱,应该没问题吧
    2025-11-11 10:43
  • 0关注人数
  • 18浏览人数
  • 最后回答于:2025-11-11 10:03
