CD20160914Lv8专家互助发布于4 天前(编辑于 4 天前)
${if(len(科室1)>0,"and 字段名称='"+科室1+"'","and 字段名称='"+科室2+"''")}
帆软用户Hw32qe7nXw(提问者)
- 我之前的数据源里面是这样设计的 ${IF(DEPT == 'all',""," AND DEPT_CODE IN ( '" + REPLACE(DEPT,",","','") + "')")}, 加第二个该怎么写呢
CD20160914 回复 帆软用户Hw32qe7nXw(提问者)
- 类似这样:${IF(DEPT == 'all',""," AND DEPT_CODE IN ( '" + REPLACE(DEPT,",","','") + "')"
," AND DEPT_CODE IN ( '" + REPLACE(DEPT2,",","','") + "')")}
- 如果字段不一样,你改一下字段名称就行了
帆软用户Hw32qe7nXw(提问者) 回复 CD20160914
- 好的 谢谢
我试试
- 好的
