FineReport填报提交分月份数据时,偶尔出现某月数据提交错误是为什么?
com.fr.write.WriteSubmitException: 子查询返回的值不止一个。当子查询跟随在 =、!=、<、<=、>、>= 之后,或子查询用作表达式时,这种情况是不允许的。
异常位置
sheet:sheet1
填报属性:内置SQL1
at com.fr.write.DBCommitWrapper.commit(DBCommitWrapper.java:120)
at com.fr.write.DBCommitWrapper.commit2db(DBCommitWrapper.java:43)
at com.fr.report.write.BuiltInSQLSubmiter.execute(BuiltInSQLSubmiter.java:106)
at com.fr.report.write.ReportWriteAttr.submit(ReportWriteAttr.java:231)
at com.fr.report.write.SubmitHelper.submit$original$sZQTaUJV(SubmitHelper.java:79)
at com.fr.report.write.SubmitHelper.submit$original$sZQTaUJV$accessor$ygU9VGMp(SubmitHelper.java)
at com.fr.report.write.SubmitHelper$auxiliary$YniysFZa.call(Unknown Source)
at com.fr.report.core.ExceptionLocateInterceptor.intercept(ExceptionLocateInterceptor.java:27)
at com.fr.report.write.SubmitHelper.submit(SubmitHelper.java)
at com.fr.report.write.SubmitHelper.submit(SubmitHelper.java:126)
at com.fr.web.core.bochavy.FbtfrGjrdamLwiimpXasipp.actionCMD$original$Lw52iAaB(Unknown Source)
at com.fr.web.core.bochavy.FbtfrGjrdamLwiimpXasipp.actionCMD$original$Lw52iAaB$accessor$5A6BOyfF(Unknown Source)
at com.fr.web.core.bochavy.FbtfrGjrdamLwiimpXasipp$auxiliary$pjauyqQe.call(Unknown Source)
at com.fr.intelli.metrics.MonitorInterceptor.intercept(MonitorInterceptor.java)
at com.fr.web.core.bochavy.FbtfrGjrdamLwiimpXasipp.actionCMD(Unknown Source)
at com.fr.web.core.WebActionsDispatcher.dealForActionCMD(WebActionsDispatcher.java)
at com.fr.web.core.WebActionsDispatcher.dealForActionDefaultCmd(WebActionsDispatcher.java)
at com.fr.web.core.bochavy.FbtfrGtjocxa.process(Unknown Source)
at com.fr.web.core.ReportDispatcher.dealWithOp(ReportDispatcher.java)
at com.fr.web.core.ReportDispatcher.dealWeblet(ReportDispatcher.java)
at com.fr.web.core.ReportDispatcher.dealWithRequest(ReportDispatcher.java)
at com.fr.web.controller.BaseRequestService.handleRequest(BaseRequestService.java:40)
FineReport 南宫北燕 发布于 2025-11-22 16:45
发布于2025-11-22 16:47
检查你的数据集 子查询返回了多个值【子查询返回的值不止一个
比如一个ID号返回了两个值
  • 南宫北燕 南宫北燕(提问者) 只是通过EXECL表格导入数据以后,然后点提交出来这提示呢,还有什么子查询呢
    2025-11-22 18:10
小李同学奥Lv4见习互助
发布于2025-11-22 16:55
数据不唯一导致的报错
发布于2025-11-22 17:21
如果子查询用等于就改成in,如果是其它运算符就限制子查询返回一个值比如用top 1或者limit 1
  • 328浏览人数
  • 最后回答于:2025-11-22 17:21
