有一部分的看板能打开,还有一部分的看板打不开,打不开的日志就会报这个错误 2021-03-09 15:33:37 正常:正在打开"业绩详表2.cpt",请稍候... 2021-03-09 15:33:38 警告:com.fr.chart.chartattr.Plot.setDataProcessor(Lcom/fr/base/chart/chartdata/model/DataProcessor;)V at com.fr.plugin.chart.vanchart.VanChart.readChartXML(Unknown Source) at com.fr.chart.chartattr.Chart.readXML(Unknown Source) at com.fr.stable.xml.XMLableReader.readXMLObject(Unknown Source) at com.fr.chart.chartattr.ChartCollection.readXML(Unknown Source) at com.fr.stable.xml.XMLableReader.readXMLObject(Unknown Source) at com.fr.xml.ReportXMLUtils.tokenizeDetailObject(Unknown Source) at com.fr.xml.ReportXMLUtils.access$000(Unknown Source) at com.fr.xml.ReportXMLUtils$ReportObjectTokenizer.tokenizerObject(Unknown Source) at com.fr.general.xml.GeneralXMLTools.readObject(Unknown Source) at com.fr.report.cell.AbstractCellElement.doWithChildNode(Unknown Source) at com.fr.report.cell.AbstractCellElement.readXML(Unknown Source) at com.fr.report.cell.AbstractWidgetCellElement.readXML(Unknown Source) at com.fr.report.cell.AbstractDynamicCellElement.readXML(Unknown Source) at com.fr.report.cell.AbstractInsertCellElement.readXML(Unknown Source) at com.fr.report.cell.AbstractExpandCellElement.readXML(Unknown Source) at com.fr.report.cell.DefaultTemplateCellElement.readXML(Unknown Source) at com.fr.stable.xml.XMLableReader.readXMLObject(Unknown Source) at com.fr.report.elementcase.AbstractElementCase$1.readXML(Unknown Source) at com.fr.stable.xml.XMLableReader.readXMLObject(Unknown Source) at com.fr.report.elementcase.AbstractElementCase.readXML(Unknown Source) at com.fr.report.report.AbstractECReport.readXML(Unknown Source) at com.fr.report.worksheet.WorkSheet.readXML(Unknown Source) at com.fr.stable.xml.XMLableReader.readXMLObject(Unknown Source) at com.fr.main.AbstractFineBook.readReportXML(Unknown Source) at com.fr.main.AbstractFineBook.readXML(Unknown Source) at com.fr.main.AbstractTemplateWorkBook.readXML(Unknown Source) at com.fr.stable.xml.XMLableReader.readXMLObject(Unknown Source) at com.fr.main.impl.WorkBook.readStream(Unknown Source) at com.fr.main.impl.WorkBook.readStream(Unknown Source) at com.fr.design.module.DesignerModule$5.asIOFile(Unknown Source) at com.fr.design.module.DesignerModule$5.asIOFile(Unknown Source) at com.fr.design.module.DesignerModule$AbstractWorkBookApp.openTemplate(Unknown Source) at com.fr.design.mainframe.DesignerFrame.openFile(Unknown Source) at com.fr.design.mainframe.DesignerFrame.openTemplate(Unknown Source) at com.fr.design.file.TemplateTreePane.openSelectedReport(Unknown Source) at com.fr.design.file.TemplateTreePane$2.mousePressed(Unknown Source) at java.awt.AWTEventMulticaster.mousePressed(Unknown Source) at java.awt.AWTEventMulticaster.mousePressed(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$500(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) 2021-03-09 15:33:38 正常:模版WorkBook5已经关闭. 2021-03-09 15:33:38 正常:"WorkBook6"已经打开! |
