js截取字符串
'{42AF0A96-83D5-4769-880E-1FF092EB1ACD}','{4717A6B2-9A06-4CCB-9638-D09903FBF042}'
这个字符串 我想去掉第一个单引号和最后一个单引号
{42AF0A96-83D5-4769-880E-1FF092EB1ACD}','{4717A6B2-9A06-4CCB-9638-D09903FBF042} 最后成这样
C罗陈悦 发布于 2021-5-25 17:19
jongwangLv6中级互助
发布于2021-5-25 18:20(编辑于 2021-5-25 18:21)
var str = "'{42AF0A96-83D5-4769-880E-1FF092EB1ACD}','{4717A6B2-9A06-4CCB-9638-D09903FBF042}'";
var str_new = str.substring(1,str.length-1);
console.log(str_new )
qhlLv6中级互助
发布于2021-5-25 17:31(编辑于 2021-5-25 17:31)
replace(replace("'{42AF0A96-83D5-4769-880E-1FF092EB1ACD}','{4717A6B2-9A06-4CCB-9638-D09903FBF042}'","'",""),",","','")
先把单引号替换为空,然后把逗号替换成','
luojian0323Lv7资深互助
发布于2021-5-25 18:16(编辑于 2021-5-25 18:28)
var str="'{42AF0A96-83D5-4769-880E-1FF092EB1ACD}','{4717A6B2-9A06-4CCB-9638-D09903FBF042}','{654736B2-9A06-4gfdsfB-9638-85432zfDBF042}'"
    str =str.split("','")
   var  arr=""
    for (i=0;i<str.length;i++){
        if(i<str.length-1){
        str[i]=str[i].replace("'","")
        arr=arr+"','"+str[i]
    }else {
        arr=arr+str[i]
    alert(arr)
  • 804浏览人数
  • 最后回答于:2021-5-25 18:28
