下拉框提示参数配置有问题,但是设计器预览正常,分页预览选择下拉框查询后报错,求大佬解决,非常感谢
select  Row_number() over(order by CreateTime desc ) as id, (Cast(ProjectId as varchar(250)) +'\n'+ Cast(projectname as varchar(250))) as ProjectIdname,BidderName,contactuser,contactuserphone,
case when PayerType=1 then '报名收费' when PayerType=2 then '中标收费' when PayerType=3 then '保证金' else '' end as PayerTypeStr
,payamount,case when PayStatus=1 then '已支付' else '未支付' end as PayStatusStr,recommendusername,CreateTime  from
(select  a.ProjectId,c.projectname,a.BidderName,contactuser,contactuserphone,payertype,payamount,paystatus,
recommendusername,a.createtime from
(select  ProjectId,BidderId,BidderName,paystatus,payamount,createtime  from  Product_FeeBidder)a
left join User_BiddingSubInfo b on a.BidderId=b.BiddingSubInfoid
left join Product_FeeProject  c on a.ProjectId=c.ProjectId
UNION all
select projectid,projectname,biddername,contactuser, contactuserphone, payertype, TradeMoney, paystatus,recommendusername,CreateTime from
(SELECT bidderid,biddername ,InSubAcc,3 as payertype,TradeMoney,1 as paystatus,CreateTime FROM Product_FNTDInAccRecord where  bidderid is not null )a
inner join
(SELECT ProjectId,Projectname,SubAcc FROM  Product_FNTDProjectSubAcc)b on a.InSubAcc=b.SubAcc
left join
(SELECT BiddingSubInfoid,subname,contactuser,contactuserphone,recommenduserid,recommendusername from User_BiddingSubInfo
where BiddingSubInfoid in (SELECT distinct bidderid FROM Product_FNTDInAccRecord))c
on a.bidderid=c.BiddingSubInfoid )data1 where  1=1
 ${if(len(payertypestr) == 0,"","and payertypestr = '" + payertypestr + "'")}
 ${if(len(paystatusstr) == 0,"","and paystatusstr = '" + paystatusstr + "'")}
  ${if(len(BidderName) == 0,"","and biddername like'%" + BidderName + "%'")} ${if(len(recommendusername) == 0,"","and recommendusername like'%"+recommendusername+"%'")}
  ${if(len(创建时间)=0,""," and CreateTime>='"+创建时间+"'")} ${if(len(至)=0,""," and CreateTime<'"+至+"'")}
FineReport yzc888 发布于 2021-5-31 15:11
奥奥奥Lv3见习互助
发布于2021-5-31 15:21
你把你这里先删了就用第一个看看可以吗
  • yzc888 yzc888(提问者) 不管,也是报一样的错误
    2021-05-31 15:29
  • 奥奥奥 奥奥奥 回复 yzc888(提问者) 那你试试在帆软里面查询,给下拉框要传参的数据传参看看能执行吗
    2021-05-31 15:44
  • yzc888 yzc888(提问者) 回复 奥奥奥 已找到解决办法,语句再套一层,select * from (data1)data2 where 1=1 参数,谢谢~
    2021-05-31 15:54
  • 305浏览人数
  • 最后回答于:2021-5-31 15:21
