本地可以运行程序,但是用intellij idea编译器 build后,放到帆软编译就出错,查看数据集,一直在加载数据,然后最后出现空指针错误 以下是处理接口返回数据的代码 CloseableHttpClient httpClient = HttpClients.(); HttpPost httpPost = HttpPost(); httpPost.addHeader(,); httpPost.addHeader(,); Map map = HashMap(); map.put( , ); map.put( , ); map.put( , ); map.put( , ); map.put( , ); map.put( , ); JSONObject jsonString = JSONObject(map); StringEntity entity = StringEntity(jsonString.toString(),); httpPost.setEntity(entity); CloseableHttpResponse response = ; { response = httpClient.execute(httpPost); } (IOException e) { e.printStackTrace(); } HttpEntity responseEntity = response.getEntity(); System..println(+responseEntity); String entityString = ; { entityString = EntityUtils.(responseEntity); } (IOException e) { e.printStackTrace(); } Object[][] datas = Object[][]; JSONObject jsonObject = JSONObject.(entityString); (jsonObject.getInteger()!=){ datas[][]=; datas[][]=; datas[][]=; datas[][]=; datas[][]=; datas[][]=; datas[][]=; .=datas; ; } JSONArray array = JSON.((jsonObject.getString())); Iterator<Object> iterator = array.iterator(); i=; (iterator.hasNext()) { JSONObject obj = (JSONObject) iterator.next(); (obj.get()!=&&obj.get()!=){ datas[i][]=obj.get().toString(); } datas[i][]=; (obj.get()!=&&obj.get()!=){ datas[i][]= obj.get().toString(); } datas[i][]=; (obj.get()!=&&obj.get()!=){ datas[i][]= obj.get().toString(); } datas[i][]=; (obj.get()!=&&obj.get()!=){ datas[i][]= obj.get().toString(); } datas[i][]=; (obj.get()!=&&obj.get()!=){ datas[i][]= obj.get().toString(); } datas[i][]=; (obj.get()!=&&obj.get()!=){ datas[i][]= obj.get().toString(); } datas[i][]=; (obj.get()!=&&obj.get()!=) datas[i][]= obj.get().toString(); datas[i][]= ; i++; } System..println(+datas[][]+datas[][]+datas[][]+datas[][]+datas[][]+datas[][]+datas[][]); System..println(+i); .=datas; |
