对字段值判断来确定显示内容
数据表shuju有kstime 和jstime、neirong字段,
原来的语句:
select  (cast(isnull(kstime,'') as varchar(8))+'至'+cast(isnull(jstime,'') as varchar(8))+cast(neirong)) as aaa from shuju
现在想实现的是,如果JSTIME为空值,查询出的内容就不包含'至'+cast(isnull(jstime,'') as varchar(8))的内容,就是不显示“至”,在数据集里面如何写判断语句。谢谢!
FineReport bsthq 发布于 2021-8-11 09:12 (编辑于 2021-8-11 11:59)
SurnameLv4见习互助
发布于2021-8-11 09:17(编辑于 2021-8-11 13:51)
数据集中你这样写试下   数据库名更换下
例子:
${if(sql("数据库名","select count(*) from jstime",1,1)=0,"select  concat(cast(isnull(kstime,'') as varchar(8)),'+',cast(neirong)) as aaa from shuju","select  concat(cast(isnull(kstime,'') as varchar(8)),'至',cast(isnull(jstime,'') as varchar(8)),cast(neirong)) as aaa from shuju")}
发布于2021-8-11 09:16
度娘了解一下
case when then else end
发布于2022-2-22 18:21
select
${if(len(JSTIME)=0,"(cast(isnull(kstime,'') as varchar(8))+cast(neirong))",
"(cast(isnull(kstime,'') as varchar(8))+'至'+cast(isnull(jstime,'') as varchar(8))+cast(neirong))")} as aaa
from shuju
  • 657浏览人数
  • 最后回答于:2022-2-22 18:21
